F-250 / Super Duty / Diesel
Did the DIY Intake today...
Old 04-30-2008, 04:54 PM
Zaairman's Avatar
Got it done today... Used a 5" long piece of 4" pipe and it was probably 1-2" too long, but I made it work. Cut the factory battery box after I removed the factory air box. Slid the battery box forward 1" for the filter to fit properly. Of course, here's the pics:
Haven't really gotten a chance to drive it much but around the block, but daaaaaayum, seems like it helped out rather nicely. I hit "way too fast" really fast.
Old 04-30-2008, 05:22 PM
Contributor
How does the turbo sound. Is it louder?
What do you mean by "way too fast"? You mean speed or in PSI boost?
Can you make a new video of it?
Old 04-30-2008, 06:07 PM
dirtyd88's Avatar
yea, id like to see/hear this. might be a mod worth while for my dad to look at doing on his 7.3.
Old 04-30-2008, 08:08 PM
ford7.3SD's Avatar
I should have done that insted of my AEM one i put on, it looks like it will flow more. Looks good man!
Old 04-30-2008, 09:28 PM
powerstroke73's Avatar
Lose the worm gear clamp on the fiter ASAP. A worm gear clamp doesn't provide near enough clamp load to properly make the neck of that particular filter seal. A high torque clamp is required there. That filter has a particularly stiff neck and requires much more torque than you think to seal it.
Quick Reply: Did the DIY Intake today...
