2008 exhaust?
2008 exhaust?
What kind of problems am I going to run into with aftermarket exhaust on my 2008 diesel. I know it has some sort of canister deal that I assume is some sort of additional emitions reducer. I don't know how removing this will affect the computer, drivability, etc. Thanks, Lewis.
i just went with a sinlge 4in mbrp 409 stainless seams to be the best price for what your getting out of it considering its only benefit is the looks. I believe i paid around $250 were as the dual exit pipes are double that and the banks or magnaflow systems are $400+ also.
The first thing I am doing tomorrow when I get home is remove the tip thing. I so want to see the Flames shooting out the back of my truck.
![Roll Eyes (Sarcastic)](https://www.f150online.com/forums/images/smilies/rolleyes.gif)
The 6.4 exhaust has 3 temp sensors and 1 pressure sensor, these are all under the truck, crawl under and look. If you make any modification and you take it to a dealer for a problem, you're probably going to be SOL! The twin tips are suppose to help cool the exhaust by sucking in outside air. As for seeing flames, good luck! The guy in that video had one of the very first job 1's with 2 bad injectors. Ford made sure those don't exsist.
