could it tow this?
heres what im towing
http://www.bobcat.com/publicadmin/ge...9676&width=400
http://www.bobcat.com/publicadmin/ge...5764&width=315
and in the near future
http://images.google.com/url?q=http:...czXPNjQrLrIETQ
I have pulled about 20K lbs with my truck (pintle). However it was short distances (10 miles) between farms and never was bothered by a weighmaster. If I was on a hwy I would have been cited....plus if I was going at speed (over 40 mph) it would have been unsafe.
The F450 Dually would have no problem actualling pulling it, but I don't know about legality as Powerstroke73 mentioned
If i remember right towing aything over 10,000 lbs requires a CDL. I haul the load your talking about all the time but i use my F-800 and 20 ton tag trailer with air breaks. Overkill for the load? Yes..but i need that set up to haul my other equipment. If you want to haul both of those machines at the same time i would be looking for atleast a F-650 with around a 10 ton trailer. You do not need USDOT numbers if you are staying in state. If your going to tow this you should atleast do it in a safe manor. Theres enough guys out there now that give the guys doing it leagly enough trouble.
Over 10k requires only a med card. My company used to go by that until we were finally able to find in writing where it states that we can tow up to 26k gross with only a med card. Once we hit 26,001 we need a class A.
Yes its roughly a 20k load capacity trailer (rated at 25,900 GVW), but as I stated its overkill for hauling your 2 rigs. The weights I stated were gross weights of the trailers. The useable capacity of the trailer are probably around 14k-16k by the time you take out the trailer weight.
You are hauling around alot of very heavy equipment, and I'll bet that you're also hauling other supplies such as tools, shovels, rakes, occasionally dirt, etc. Plus now you're talking about a Kubota with a backhoe attachment. You'd be FAR ahead to get rid of the F450 and step up to an F650 or larger. It'll cost more, but in the end it'll handle the load alot better. Heck you've got to get a CDL anyways to pull this weight around.
No to pull what he wants to he will need his Class A, not B. Class B is only for a straight truck ex(box truck, dump truck, etc..) and your only allowed to tow 10,000 lbs with the Class B. You need the Class A for this weight.. Theres is almost no way off avoiding the CDL to pull these machines at the same time.
