could it tow this?
could it tow this?
could an 08 f450 tow this trailer??
http://i17.ebayimg.com/02/i/000/ef/52/cac6_12.JPG
http://i11.ebayimg.com/06/i/000/ef/52/cbdc_12.JPG
The pin weight of that trailer is going to be too much for anything less than an F650. The tounge weight of the trailer is going to be insane as others have pointed out. To be honest you are going to have a hard time finding a light duty towing setup that can legally handle that kind of weight and still be under a CDL requirement.
The problem you have is that just the truck itself will be pushing 10k lbs depending how you option it and what bed you get. If you have a large dump box or flat bed you'll probably be up around 12k. The lightest you could get it should be somewhere around 9k. Now to the trailer. The trailer you found weighs AT LEAST 5500 lbs empty. My guess is that its 6k or higher. There is alot of steel in there that is taking away from your towing capacity. Looking on Ford's site the 08 F450 in a crew cab pickup configuration has a GCWR of 29k (if you have the 4.30 gears). That right there puts you in Class A CDL territory when you put the trailer on because its over 26k. This means that bumper hitch total trailer weight can't exceed 16k. There is no way that you can haul both excavators on that trailer an be legal.
Heres some cliff notes:
T190 weight = 7615lbs
334 weight = 7538 lbs
Trailer weight = 5500lbs+
Truck weight = 9K+ depending on configuration
Total = 29653lbs best case scenario, plus this requires a CDL and USDOT numbers if its being used for a business. An F450 can do it, but it can't be a bumper hitch trailer, and it must have 4.88 gears to get the 33k GCWR option.
it has 4.88 gears and that option also. im looking into fifth wheels now i guess.
You're still completely missing the point here. You are looking at trailers that are WAY WAY too big for the load you're talking about hauling. To be able to carry loads that large the trailers get progressively heavier. The load you're talking about hauling is only slightly over 15k. You need to be looking at 18-20k GWR trailers depending on what the unladen weight of the trailer is. You do understand how all the towing and vehicle weights work don't you?
You also are not going to be able to haul your 2 bobcats at the same time without first getting your class A CDL. The size of truck and trailer required to pull a 15k payload puts you in excess of 26k.
