Parking Garages....
With my '08 250, I've learned (the hard way) that the garage needs to have a clearance of at least 6'8". I went into one that was 6'7" and it was just low enough for me to put a light scratch on the roof. (and my truck is bone stock!)
BTW... I had to replace my antenna after 6 months because it "slapped" the beams in the parking garage so often. Finally, it was so cold out side, the antenna just snapped off!
I think its vehicle descrimination!! I would go to the buildings owner and demand a spot or a lawsuit will follow... Just kiddin... the 6.6 probably means there is a light fixture that is low or there could be a speed bump that makes it that hight as well.. have a buddy ride in the bed and slowly try to make it in, let him keep a watchful eye..
I dont remember if i read it on this site somewhere or if someone told me about this but there was someone that cut there antenna down to where it was just a lilttle bit taller then the truck. That way when you pull into something if it hits then you know you better not go there.
