Buying a used turbo diesel...
There is no valve adjusting to be done I would go with the PSD it has alot better drive line I have herd that the dodge has a really week tranny..And plus the ford comes with a 100k war. on the motor.. Try to get a 96 or a 97 they raised the HP to 215 from the 210 and if you put a chip in you will have the same or more power than the new ones...hope this helps
my dad has a 96 PSD with 50K and has not been in the shop yet..
Allan
1999 F150 Bright Red Extended Cab 4x4 Off Road, With Gray Interior, 5.4L, 3.73 Gears,
Add On's for now!
Access Tunnel Cover
Stainless Steel Nerf Bars
Stainless Steel Rocker Pannels
Putco Bed Rails
Clear Turn Signals
Flowmaster Exhaust
Lund Bug Guard
Painted Vent Shades
Painted Taillight Covers
Painted X-Cab Covers
Superchip (in and loveing it)
Airaid FIPK
Red Stering Wheel Cover
Pionneer CD Deck
Wish List: F1 Ram Air Hood, Tinted Side Windows, Wiper Crawl, Viser, Supercharger, NOS, ETC...
Allan
Add On's for now!
Access Tunnel Cover
Putco Bed Rails
Clear Turn Signals
Flowmaster Exhaust
Lund Bug Guard
Painted Vent Shades
Airaid FIPK
Pionneer CD Deck
Really, the cummins is a good engine. You didn't state whether your getting a manual or a automatic. Early Psd's had/have so much power they'd eat a E40d. I would suggest a manual for a 94.5-97. I think Ford uses a better tranny (4R100) now, which is a whole lot better. I have only heard of a few cases where Dodge trannys are eaten by the cummins. We have several 94.5-97 PSD's that are shop/work trucks, most all are manuals, and have been good engines. I honestly think the 96-97's have a bit more power than the new ones. Maybe its because of the tranny? Good luck!
I'm thinking about buying a '95-'97 F250 PSD
extended cab 4x4. I'm also considering a '95-'97 Dodge Cummins. I'm leaning towards the PSD because the 12 valve Cummins requires
valve adjustments every 48K. Does the PSD need valve adjustments, if so how often?
Are there any other maintenance requirements other than fluid and filter changes?
Thanks!!!
Thanks!!!
Another place to get some really great info on the diesel is www.ford-diesel.com They can probably even give you info on the cummins. Have you been able to find any trucks that you like and how much ($$$) are they running??? I too agree w/the part about getting a manual over the automatic but if you don't like/drive them then the point is moot. Good luck w/your search and let us know what you end up with.
2k F250 CC SWB 4x2 6 speed Diesel XLT Super Duty, Woodland Green
Power Mirrors, 3.73 LS, Captains Chairs, ARE tonneau top, rear privacy glass
TT Pkg, Class IV hitch, sliding rear window, running boards, mud flaps
265/75/16 AS OWL tires, am/fm/cassette/cd, rechargable MagLite
Clarion APA 5240 amp, Memphis speakers:Components front, 5x7 rear, 10"sub
SuperChip, Stepshields, Ventshields on windows, rubber bed mat
rugged liner bedliner on tailgate, quick disconnect jumper cables
unaFORDable (decal on tailgate)
Well my dad had is first problem the injector pump went out but was covered by ford so he did not have to pay anything. with tranny problems I haven't herd that but then agin my dad has a chip in his and so that helps out a lot.. Happy PSD hunting
(try to get one that a contractor did not own)
Allan
Add On's for now!
Access Tunnel Cover
Putco Bed Rails
Clear Turn Signals
Flowmaster Exhaust
Lund Bug Guard
Painted Vent Shades
Airaid FIPK
Pionneer CD Deck
Allan
Add On's for now!
Access Tunnel Cover
Putco Bed Rails
Clear Turn Signals
Flowmaster Exhaust
Lund Bug Guard
Painted Vent Shades
Airaid FIPK
Pionneer CD Deck
