Best Manual Trans Fluid for 5 speed??
Picked up a 1997 F250 7.3 a few weeks ago. Have been noticing that the manual transmission is pretty 'notchy' and maybe this is normal for this transmission but I was going to start with changing out the fluid first since the truck has 174k miles on it. Does anyone have any suggestions for a fluid that might help smooth it out? Or should I just use the OEM lube?
Thanks in advance -
Thanks in advance -
Good morning!
Some folks on here have had great success with:
Amsoil ATF: ==> http://www.amsoil.com/storefront/atf.aspx
Now - you may perhaps have heard that Amsoil also makes a Manual tranny fluid. However, if you would please peruse the info in this link: http://www.amsoil.com/products/trans...fluid_rec.aspx, you'd see that it was meant for non-Ford applications. ATF is the fluid of choice for Ford manuals.
I hope this was even infinitesimally helpful. Please let me know if you have any more questions, or would wish to delve into this site's excellent Search features.
Bests & regards;
MGD v2.1b
Bests & regards;
MGD v2.1b
product lookup guide
Good suggestions. There is also a really good Amsoilproduct lookup application online that lists the oils spec'd for any vehicle use, as well as capacities and other useful information.
Hope this helps,
JL
Hope this helps,
JL
Good morning!
Bests & regards;
MGD v2.1b
Bests & regards;
MGD v2.1b
