ATTN: fellow 6.0 technicians
#32
the duramax may be more reliable then the 6.0 and 6.4 and the allison is a good transmission. but I cant stand the rest of the truck.
ive been looking at a new 6.7 on a stand for the past 4 days and get to see my first 2011 6.7 truck tomorrow. and let me tell you Ford has done their homework on this engine.
the egr cooler can be out and on the bench in 30minutes, the oil cooler sits right beside the oil pan and can be removed in about 10 minutes. The egr valve is moved from the cold side to the hot exhaust side to reduce carbon buildup. The high pressure fuel pump is out right in front of the engine. all the injectors and glow plugs are accessable from outside(no more removing valve covers for these items) the lower section of the oilpan is a composite peice and separate from the rest and could be removed in 5 minutes if the pickup needs to be inspected. I can go on and on....to the untrained eye it looks like it might be packed in there and hard to work on...but its not. Its an engineering masterpeice IMO.
#33
#34
#35
^^^^^ Agreed
I just finished my training on the 6.7L on friday. Looks like the best engine out there. Really accessable and won't have same failures as 6.0L. I'm also glad its not a HEUI engine anymore
#36
#37
Hey you guys, I ran into a 6.0 today that is giving me the hardest time!!! Ford just recently put new injectors in holes 1,3,5,7. It still runs rough, white smoke no power. On power balance, number 7 is ALWAYS down. I kill it and it helps nothing. Soon while after it will take out 3,1, and 5. Motor will run and eventually die. I took fuel pressure at that head, its the same as at the 2nd fuel filter... I found the filter cap on the rail not tight, maybe thats where it was sucking air in at and wiped out those injectors???
I havent but a few hours in it yet, just wondering any opinions... The oil side is fine, ICPA and ICPDes are dead on.
#40
#41
turns out that truck just needed injectors AGAIN... junk was put in...
BTW- how do you guys test to see if a EGR cooler is plugged up on the exhaust side??? I put 5- PSI through the tail pipe, pulled out the EGR valve and had next ot nothing coming out. I took the EBP sensor out and the air was SHOOTING out, so it isnt a clogged cat.. I got a doggy truck that wont pass MAP nor EBP tests, EGR codes...
#42
#43
they were fine together... I have never seen the exhuast side plugged either, but tha tdoesnt explain next to no flow when i have over 50 pounds coming in at the tailpipe... it should be a straight shot... before I pulled the EBP sensor out, I turned key to read the pressure I had in the system, it was about 52 PSI, so the EBP sensor is good
#45
