F-250 / Super Duty / Diesel
ATTN: fellow 6.0 technicians
Old 03-17-2010, 08:57 PM
Paralyzer's Avatar
Thats not how you test an EBP sensor. Im tellin you you NEED to compare EBP and MAP and make sure they are within 5psi KOEO. Also you will not have flow into the intake without the EGR valve commanded open.
  #47
Old 03-17-2010, 08:59 PM
Camarothatcould's Avatar
that wasnt a test to test the EBP sensor, it was to see if the EGR cooler was clogged. I had the EGR valve out, so it doesnt matter, the EBP sensor in inspect to what you had said, it has been tested. The issue here is the lack of flow out of the EGR cooler into the intake...
  #48
Old 03-17-2010, 09:09 PM
Paralyzer's Avatar
Do you guys use an IDS? Im curious as to why you are looking into this do you have DTCs? What is the complaint?
  #49
Old 03-17-2010, 09:12 PM
IDS yes.... The truck feels doggy on low end, doesnt feel like a 6.0. I also throw codes during the EGR test and KOER on demand. Both codes are insufficent EGR flow and EGR flow out of range.
  #50
Old 03-17-2010, 09:18 PM
Paralyzer's Avatar
If you have a known good EGR valve now is the time to install it and re-run the egr test. Usually TOO MUCH egr flow causes power problems though. Not enough is a good thing for power
  #51
Old 03-17-2010, 09:23 PM
put a new egr valve in, re ran test, failed...
  #52
Old 03-17-2010, 09:31 PM
Paralyzer's Avatar
at what point?
  #53
Old 03-17-2010, 09:33 PM
it failed right after you have to start up and run the truck. First time the MAP failed, than the EBP was too high, than the MAP was also too high
  #54
Old 03-17-2010, 09:37 PM
Paralyzer's Avatar
ok. i dont mean to sound like an a-hole. but you need to verify the EBP sensor as i said earlier.
  #55
Old 03-17-2010, 09:40 PM
Will do tomorrow. The truck has been passed around the shop a few times, I was goin off what I was told.... So I am watching the EBP and MAP, they must be within 5 PSI of each other? I assume EBP Actual?
  #56
Old 03-17-2010, 09:41 PM
I still need to find out why I have no flow out of the EGR cooler exhuast side when pressurized... it I have the 50 some pounds blowing out the EBP tube, than it shoul dbe screaming out the hole where EGR valve goes
  #57
Old 03-17-2010, 09:43 PM
we use IDS at Land Rover, actually now its called SDD (symptom driven diagnostic)
  #58
Old 03-17-2010, 09:48 PM
IDS is amazing... better than MDTruck for the 4.5L's and such
  #59
Old 03-17-2010, 09:51 PM
Paralyzer's Avatar
my bad i made a typo. it is within .5 of eachother KOEO. will both most likely be in the 15psi range. the EBP usually read higher when the sensor gets skewd up into the 20psi range.
  #60
Old 03-17-2010, 09:57 PM
alright, awesome... I'll let you know everything as I am doing the test, I can be on the forum and run the tests on the same laptop... THANKS!
Quick Reply: ATTN: fellow 6.0 technicians
