A/C Not Blowing Hard At All
The A/C in my dad's 04 F-350 Superduty just flat out doesn't blow at all. There is a little bit of pressure that comes out but not much. It's almost as if there is a filter plugged full of dirt or something. Does anyone know where there may be one to clean or where maybe something could be clogged up? Thanks, Brent
I have an easy fix for a/c not blowing hard.
done this on a 97 f-150. in the passenger floorboard directly under the glove box is a black cover with a few screws. remove it. directly in front of the blower motor you will see a plastic rectangle about an inch wide by a foot long. use a utility knife & cut it out. take a wire brush to the condenser coil inside & tons of gunk will come out. spray it with a heavy cleaner like clr or alumibrite & let dry. glue or tape the rectangle you cut out back on. reinstall cover & your air will blow like new again. 15 min job. find pics by searching f150 cabin filter installation.
