Project Mean Green
yeah I figured as much... the passenger side one on my truck is broke and the wife can't get in.....
wouldn't happen to be around Kenora, ON would you? headed up for a hunting trip in 2 weeks LMAO Like I have that kind of luck....
Oh well. When my wife couldn't get into one of my trucks, I gave her a milk carton and a piece of rope.
The log is for my garage in general. What work I did on what, and when I did it. No cost of anything, though, the wife could find it.
Some update pics....
Well the truck is all back together and mobile. Got my plates and insurance now. Tonight I fixed the airbag light that was coming on, and installed a 200amp glow plug relay.
Here are some pics.
Thats a pail of Shaeffer's supreme alltrans synthetic transmission fluid. It's what Brian's Truck Shop recommends. I had to special order it. Stuff like that is not readily available up here. The trans took 19 quarts.
Removing the restrictive Intake Air Heater.
Here's the intake heater delete plug from Riffraff Diesel installed with an Isspro turbo boost sensor in it. You can also get the plug with no boost sensor port.
Here are some pics.
more..
Heres the new glow plug relay. It's rated for 200amps. Glow plugs are very important in this climate, as are block heaters.
Here's a pic of the relay installed. It's a bit bigger but still fits with a bit of trimming to the base.
The relay just to the front of the glow plug relay is for the intake air heater. I took the output wire off it and will probably get rid of it all together later on.
Tonight I got my 3 gauges installed and wired up.
I also swapped out the CD player to the factory one that came out of my wifes 02. The one in the truck was skipping on gravel road. It also had the retainer broken, so I had to remove the dash panel to get it out. Since I was in that far I replaced a few burnt bulbs in the A/C controls.
Been driving this truck a couple days now and everything seems good. Lots of power, trans shifting good, and the heater works well. Looks like it may have been 1500 bucks well spent!
I'll post some pics of the gauges later for anyone that's interested.
Here's a picture of the gauges installed.
Here's what they look like lit up. There is a **** next to the steering column to adjust the lights independantly from the dimmer switch.
I also put is some fog light bulbs tonight. I went with 9005 Silverstars. Quite a bit brighter (and whiter in color) than the stockers.
