Wires from turbo?
Wires from the turbo........seriously?
Those are the wires that control your injectors. Without them plugged in then you're only firing on 4 cylinders on the drivers side of the engine. The reason you're getting check engine lights is that one of the harnesses shorted out and caused a small fire. Thats why you have melted plastic everywhere near the one connector. The fix is a new harness from the dealer. This is a common problem and Ford has an updated harness with hold downs to keep them from unplugging on their own and shorting out like this.
