mexedbreeds next truck
#47
leo you fool..... i will see you sunday
DR, sounds good for lunch..
thanks Carolina!!!
just an update..
i took the truck through northern nevada and through lassen nat park. got 17.4 mpg doing 70-75 mph. had a huge load in the bed too, a 27 inch tube tv... damn they are heavy
in lassen by the west rim of Lake Alamore
thanks Carolina!!!
just an update..
#51
so it was a bad week for the home team last week, I was getting on it pretty hard, slowed down for a red light, and she died. would not restart hasn't started sinse. how it pulled into a apartment complex that my buddy lives that it is right down the road.
I was not a happy camper but now I guess I have to start rebuilding. I am pretty sure it is hpop related. but I need to get back in there a check for any kind of chafing on the wire harnesses.
so for right now I just have a very handsome truck parked into 2 parking spots. Lol
#55
I ran out to redding this morning and talked to Jeremy at Jefferson state diesel. He was just in diesel world mag and has a 474hp 6.0 that is a beast and identical to mine. He gave me some pointers on where to troubleshoot also. I think I might take this breakdown as an oppurtunity to rebuild everything I can. I am doing it myself as parts alone will push $2G.
#56
OK, so, i was bashing my head on the hood because nothing seemed to point out what was actually wrong with the truck. ran to the dealer and he said for $180 he would tell me what was wrong with if for sure. seemed like a reasonable price and would stop my headache.
had a flatbed come pick it up and dropped it off at 1045. at 1150 they call. "found your problem" the service rep says.. seems the jiffy lube i took it to used the wrong filter and actually broke a tab off the one they put in to make it fit and well, it ended up in my injector control pump and that is bad. sooooo $1K later and about 5 hours. i have a running truck and new filters.. now i need to go see the jiffy lube...
#57
had a flatbed come pick it up and dropped it off at 1045. at 1150 they call. "found your problem" the service rep says.. seems the jiffy lube i took it to used the wrong filter and actually broke a tab off the one they put in to make it fit and well, it ended up in my injector control pump and that is bad. sooooo $1K later and about 5 hours. i have a running truck and new filters.. now i need to go burn down that the jiffy lube...
Jiffy Lube.... Ta loco!..
#58
#59
