F-250 / Super Duty / Diesel
7.3 vacume pump always on
Old 02-11-2011 | 04:41 PM
wfo-throttle's Avatar
I isolated(capped off) the front hub vacume line close to the pump (warn manual lockouts are installed) and the pump is continuously running still. From what I've read, it only operates the front hubs and heater/AC doors. Any thoughts where to look for a leak?
Old 02-12-2011 | 02:21 AM
Zaairman's Avatar
Check the vacuum reservoir. Check the lines from the reservoir to wherever you blocked it off. I actually skipped my reservoir and plugged the line from the HVAC directly into the vacuum pump.
Old 02-14-2011 | 09:52 PM
Yeah good one, I'll do that. This should simplify things.Thanks for that. One more thing, how did you put your truck picture on your post?
Old 02-14-2011 | 11:26 PM
Zaairman's Avatar
It's in my signature...
Quick Reply: 7.3 vacume pump always on
