2002 f250 lift question
I wouldn't touch the front. First off how much lower do you want the back to sit?
The easiest way will be to lift the rear less than wht the lift requires. For instance if the kit has you lifting the front 8" and rear 6" than that would probably have the truck level. You basically would then only lift the rear 5" and it will sit 1" lower and etc.
