Programmer
What do you do with the truck heavy towing or strictly DD or a mix of both? What are you looking for out of the tuner is it for towing or performance or both? I have a SCT Xcal 3 with Innovative Perormance custom tunes (towing, extreme street, econ) and I won't run anything else. You are going to need gauges to monitor EGT's, boost, and trans temps though if you have not done an EGR delete you may want to think about while you are at it as well as rebuilding your oil cooler.
on
Check out PHP>>>www.gopowerhungry.com
If you like edge they offer something similar along with custom tunes....they are also a forum sponsor...
on
I know PHP is a site sponsor, but Eric at Innovative is one of the 6.0 tuning guru's with lots of 6.0's out there running around with his tune in them. But that's purely my .02$ after reading and researching for nearly 3 years before finally pulling the trigger on my tunes.
But just giving the OP other options....
Here are some more 6.0 tuners.
http://www.elitedieselengineering.co...ormance/1.html
www.gogodiesel.com
I don't know why people automaticly think putting a tune into a 6.0 is going to blow the head gaskets. I towed our 11k 5er this weekend round trip and was pushing 30lbs of boost going up a few hills and guess what......I don't have blown head gaskets. I also run a hotter tune when I am not towing and guess what same thing my head gaskets are still intact and I have seen 34lbs of boost while screwing around once in a while. If you drive with you foot shoved in the injection pump all the time with a very hot tune you are going to have problems but if you drive normally 85% of the time you will most likely not have any issues. My truck also has 166k on it with stock head bolts and I have a feeling I am going to be replacing the transmission before I need head studs.
