I'm really surprised you are still in the 15's even w/ your first trip to the strip.
roughly what HP are you supposed to be making with your current set up?
Truck should be in the 400-420hp range if not higher but my terrible reaction times and poor job of doing a boosted launch is what killed it. i should be able to get mid 14's but running it that night was very spur of the moment.
Originally Posted by Deereman
Jake is that time with updated mods? And what did you say you weight again? 2wd or 4wd launch? You should be faster then me.
that was just with tune, egr delete and blue spring and with 4wd launch and poor boosted launch at that, the truck weighed roughly 7300lbs but think the scale was off but it should be around the 7500lb mark roughly.
plans to head back out after the injectors etc are being worked out but is getting hot and thats the enemy at the track
