06 F250 cluster not working
Here is an update on it. None of the gauges work. The needles don't light up when lights are on. It won't accelerate very good. I think it's starting in 2nd gear. Overdrive isn't working. the computer that tells you mpg and miles to empty isn't working, but when the truck is off I shows the odometer until its started. The overhead panel has no power to rearview mirror. The engine is idling high like its been sitting in the cold and when the brake is pressed its suppose to idle down, but it doesn't, so when shifting in to reverse or drive it hits kind of hard. And now it just died and won't start it's acts like the batteries are dead but headlights are still bright radio still works until you turn the key on then the trailer brake controller and radio flicker. I called the dealer and they think it's the alternater but I've been driving it since Friday when all this happened and it sat all weekend and started just fine Monday and I drove up until now when it died.
Please help!
Please help!
