05 f250 help with codes
Two bolts hold the fuel rail down on each side. Take the two bolts that hold the fuel rail On the driver side and lift the fuel rail up with the injectors still in the rail. You should be ableto see the bottom of all four injectors now. Turn the key on and see if any starts leaking fuel out. If it does replace the injector.
