F-250 / Super Duty / Diesel
1997 f-250 5.4L neutral safety issue?
Old 06-20-2013, 04:30 PM
Light's Avatar
I've heard that a lot of Fords have this issue. I'm not sure if its the TRS (neutral safety switch) or what. My truck won't go into park/gear and will roll back (making noises) and won't start in park but will start in N The shifter doesn't go all the way into the P.
Can anyone help me fix this?
Perhaps with pictures? (I'm not mechanically inclined. but I was hoping to explain it to my dad who could fix it if he knew what it was.)
Old 06-20-2013, 04:47 PM
glc is offline
Check the bolts on the shifter tube in the steering column. They tend to loosen.
Old 06-24-2013, 12:47 PM
Light's Avatar
we tightened the bolts, it didn't fix the issue.
Old 06-24-2013, 07:51 PM
projectSHO89's Avatar
Which bolts did you tighten?
Old 07-01-2013, 02:06 PM
Light's Avatar
I think it was the ones that adjusted the ***** for the position dial thing..
Old 07-01-2013, 08:38 PM
That makes no sense.
Old 07-03-2013, 05:38 PM
adrianspeeder's Avatar
The shifter indicator knurled **** adjustment doesn't have a bearing on gear placement. You need to check and tighten the two brass colored T-35ish torqx screws under the column.
Adrianspeeder
Old 07-08-2013, 12:26 AM
Light's Avatar
How do I access it? I'm not really mechanically inclined with cars.
Old 07-08-2013, 03:40 PM
Put yer head by the brake pedal looking up. Wiggle the shifter and you'll see the two torq screws moving around when they should be tight.
Adrianspeeder
Quick Reply: 1997 f-250 5.4L neutral safety issue?
