F-250 trans stays in 2nd gear
Hi Folks,
Right now I can only get into 2nd and reverse gear. I have jumped the ground wire for the transmission so the ignition and reverse lights will work. I have a ground going to the PCM.
I have changed the battery terminals and the battery is new and voltage is correct, I checked a number of ground connections and all are solid, the engine runs normal.
Any help would be greatly appreciated as I need this truck for my job,
Thank you in advance Folks,
Pete
Pete
