F-250 / Super Duty / Diesel
No Crank/Start in Park
Old 12-15-2013, 01:22 PM
makuloco2000's Avatar
Forgot about this common issue with the Superduty and Excursion vehicle that while it won't leave you stranded, it is a pain to live with. It has to do with the shift linkage bracket bolts coming loose and losing the shift cable adjustment as a result. Check out the video, as you will likely run across this at some point in your ownership of the Superduty. I hope my video helps!
Quick Reply: No Crank/Start in Park
