F450-f550
![Talking](https://www.f150online.com/forums/images/icons/icon10.gif)
PhillipSVT
I'm running an F550 with a PSD and six speed for work. This is the best medium duty truck I have ever used, I love it. It's a 2wd with a 16' bed, some minor engine mods and acces. bolt ons. The truck has been (with the exception of a clutch repacement) pretty much flawless. Just over 100k on it now. At 19600 lbs it will pull a 6% plus grade at 65mph and still have pedal left. I love rolling past those smoking Cummins/Dodges
conner
99 F550 Superduty PSD 6speed K & N ...
![Stick Out Tongue](https://www.f150online.com/forums/images/smilies/tongue.gif)
conner
Re: f450/550
Originally posted by conner
I'm running an F550 with a PSD and six speed for work(with the exception of a clutch repacement)
hmustang
the wheel base on mine is 201"--it's just short of 28 feet bumper to bumper. not to easy to park at the local Mc Donalds and definatley not drive thru friendly
tina
i think the f250 thru 550 manuals have the same (lincoln ZF) transmission. i let the local ford dealer instal the replacement clutch, useing ford parts (they helped with some of the cost under part of the waranty) i have been told there are much better pressure plates and clutch discs available than the ford parts--next time i will go with aftermarket. mine lasted almost 100k of hard service so most should do that or more . I think the next mod will be an engine brake, how do you like yours?
thanks. conner
tina
thanks. conner
i let the local ford dealer instal the replacement clutch, useing ford parts i have been told there are much better pressure plates and clutch discs available than the ford parts--next time i will go with aftermarket I think the next mod will be an engine brake, how do you like yours?
Conner: eeeek!!! You went with the same Ford clutch!!! I've been looking into one by LUK out of NC. Price is around $600, not cheap by no means but I've talked with people that have it on their truck and they think it's been worth the money.
My exhaust brake is by www.westerndiesel.com I went to a Ford rally down in Flordia two years ago and won it (FREE) including installation. It regularly cost in the $500 range. Works GREAT!!! I leave it on all the time except when on interstate and using cruise control. When I'm towing my 30'TT it really helps in slowing down my truck. Saves a lot of brake wear when coming down a steep incline in the mountains.
