New mods- Factory Tech and GrabHandle
I just finished this weekends project of installing a drivers side grab handle on the A-pillar, and i installed the Factory Tech Valve body that has modified valves and springs. My thoughts.
While the drivers side grab handle is a good idea, hence the reason 2003's have them; it is a pain in the *ss to install. Too much modification and trial and errors. I ended up tapping and using 3/8's bolts to hold the bar there. guess i should of made a template for the bolt pattern.
The factory tech valve body mod is relatively simple. Just follow instructions and it goes well. A bit messy of course, but it has definately firmed up the 1-2 and 2-3 shifts; almost makes the truck jump into next gear. I hope to notice less slippage during shifts while pulling my trailer as well. If it makes it run cooler, i'm all for it. Tranny replacement isn't my idea of fun.
Just my thoughts...
Laters
Just my thoughts...
Laters
The factory tech valve--sounds almost like the Transgo shift kit, except I had to pull the Accumulator valve body, replace the springs with firmer, open the ports and drill a couple of vents..
It sure does make a difference on how it shifts..You did good by doing the trans mods..it is the weak point..
Had mine to the track a couple of times were I abused it..
It will light the tires up...BIG TIME....
If I wanted a Diesel, I would have bought one
"Factory_Tech" is a transmission tech at Ford, takes a brand new valvebody, installs everything and sells it for $199. You can get additional info here:
http://www.powersurgeperformance.net/shift.htm
Used by a lot of Lightning and Super Duty guys, only for the 4R100 though. Quick shifts at partial throttle, hit's hard at WOT. I love that thing How about a big 'ole relatively stock F250 4x4 that gets a little scratch on the 1-2 shift?
