Power steering leak
Steering shaft seal leaks are common, second leak maybe something that caused first leak, Just an example, contaiminated fluid that takes out the seal, or when a pump shells out and puts metal in the fluid...When the first seal went out, did you drain the whole system or just the pump fluid?? May want to consider draining as much fluid as possible...
