Ok, I finally got my overlays today and there were no directions of coarse. Is there anything I need to know or do these things just stick on? I'm affraid I might get them slightly crooked and be F'd. Any help?
spray a mix of dish soap and water on the spot you are going to apply the decal, this will allow you some play to get the decal where you want it. Then just let it dry.
don't use soap and water for the "domed" overlays as they will not stick if you do. They are easy enough to lign up without. I believe the soap and water trick will be fine for the thinner overlays.
