what is a clock spring?
The clockspring in no shape or form can cause slop or clunking in the steering column. It's only an electrical connection between the steering wheel switches and airbag and the vehicle's harness. Nothing more, nothing less. Bearings in the upper and lower column housings and the steering column shafts are usually causes for clunk/pops in Exploders and Mountaineers.
Please, just stop and go away.
This is what the paper paper work from the dealer gave to me when everythign was fixed today... Its says word by word this..
Steering Noise/movement
When going over rough roads, steering kicks. Hears Rattle in steering colume. Road tested Vehicle Verified Customer Conceren Performed Diag As Required Noise From Steering Wheel Area Found Clock Spring Bad Replaced Replaced Air Bag Clock Spring Reassemble As Nessary Noise Gone.
^^^Thats everythign they did to fix it...are you still going to say thats not the problem?
Are you ever going to remove the steering wheel to see just what they really replaced? I didn't think so, and neither does your dealer.
