Super FX4...
Super FX4...
Why does it take so long to rev up, it is in neutral right? Did you put a dodge engine in it?
Why is it so high pitched?
Sounds like a girl car......
Just razzing, it is reving slow for a GM engine, they have a short throw, a stock GM SB, just a quick blip of the throttle in neutral should hit 6K before you can let off. Even faster when built right.
Hopefully it starts with a bump of the key, if not then stop and find out why.
If it doesnt start with in 30 second of cranking, I pull the cam and reapply lube.
Start the engine and increase the RPM's to 2000-2200. Operate the engine for 15-20 minutes at this speed. The higher speeds increase splash lubrication and decrease nose loading. Vary the speed every minute or so bump the throttle to 3000-3400 for a second.
30 minutes and cam is broke in, your ready to race!!!!
Yes sir. Even though I was not able to do that exactly as described, its still has seen a fair amount of break-in. The Rotella T is still see-through clean. Gotta fire it up a few more times, change oil and reinstall my inner valve springs and I'm good to go. Gotta put a few 4.6's and LS1's to shame right away, build up my titles quick.
Originally Posted by Camarothatcould
Couldn't take it above 3k, nor any really quick revs. Cam was not fully broken in when that video was taken. Thats why
OMFG! Are those yours?!?!?!?!??!
and I couldn't do it one shot. After a few minutes, my gauge pegged at 230 and I had to shut her down. The t-stat was faulty, didnt open but a hair, replaced it and went at it again, didnt touch 210.
Oh yeah,the GNs are mine,shhh don't tell anyone I own any GM cars.
