Old 07-27-2009, 05:21 PM
awalkinrain's Avatar
Hey Cowgirl, does it fit?
I haven't been outside yet to check. I'll let you know.
  #22757
Old 07-27-2009, 07:41 PM
Administrator
Contributor
Super Moderator
You have a point there too, since I have never cleaned it before. Just regular throttle body cleaner will work, right?
Just shoot some on a rag and wipe it down, try not to give the electronics a bath, they can get kinda cranky
  #22758
Old 07-27-2009, 07:49 PM
ian51279's Avatar
Apparantly someone in town has a new '09. Bright red screw, lifted, tires too small, exhaust.
Taking up the front 4 spots at the mall.
  #22759
Old 07-27-2009, 07:51 PM
ian51279's Avatar
dang, never thought about that. Now why didn't I think of that. You have a point there too, since I have never cleaned it before. Just regular throttle body cleaner will work, right?
I've always sprayed down the inside, then some on a rag and wipe down what you can making sure to NOT touch the wires, then spray the wires with a few shots. Always worked well for me. Just don't touch the wires, they're touchy suckers.
  #22760
Old 07-27-2009, 07:56 PM
Administrator
Contributor
Super Moderator
you are probably thinking of the MAF not the TB.
BTW for those who care we had two 2010 Range Rovers show up today for sale, one already sold today, both were equipped with the new 5.0L 4v and one of them was supercharged.
  #22761
Old 07-27-2009, 08:52 PM
ian51279's Avatar
Your right Pat, my fault.
Had a brain fart.
  #22762
Old 07-27-2009, 09:25 PM
JackandJanet's Avatar
Super Moderator
It gets harder and harder to remember everything, doesn't it? Bill Cohron, at Power Hungry Performance said once that the 4.6L engine was particularly sensitive to this, and it would often show up right after "power programming". However, if the crud builds up enough, it can effect anyone. Others have said that cleaning the throttle body has fixed the problem you describe.
Here's a link to their website's FAQs. You'll find information on this near the bottom of the page. http://dygytalworld.ehost-services139.com/php/FAQs.html Of particular note (to me) is, DO NOT just spray solvent into the thing. Take it out and clean it "manually". Keep solvents away from any plastic parts. Bill suggests carb cleaner or lacquer thinner.
There was supposed to be an "anti-gunk" coating on these surfaces that you're supposed to protect, but, once it's become "gunked", I can't see that it's doing anything for you. I wouldn't worry much about the coating.
I think I read somewhere that Ford makes a special cleaner that protects the coating, if that is a concern to you.
Hope this saves you a spark plug change!
- Jack
  #22763
Old 07-27-2009, 09:54 PM
06F150STX's Avatar
Thanks guys for all the info.
  #22764
Old 07-27-2009, 10:04 PM
Administrator
Contributor
Super Moderator
I wouldnt trust carb cleaner on a TB, much less an electronic TB
  #22765
Old 07-27-2009, 10:08 PM
06F150STX's Avatar
then what should I use?
  #22766
Old 07-27-2009, 10:12 PM
Administrator
Contributor
Super Moderator
TB cleaner.
The gunk in a TB is mostly blow by oil that has hardened and penetrated the metal surface. The gunk in a carb is gasoline deposits, blow by gasses, oil and is generally baked on at higher temps because it is closer to the cylinder heads. So naturally the Carb cleaner would need to be much more harsh of a solvent to do its job efficiently.
Dont risk your electronics by using chemicals that are designed to use something else. I bet you dont use steel wool on your mother's fine china right?
  #22767
Old 07-27-2009, 10:13 PM
Administrator
Contributor
Super Moderator
hey Pam
....that has hardened and penetrated the .....
  #22768
Old 07-27-2009, 10:20 PM
06F150STX's Avatar
TB cleaner.
thanks pat
  #22769
Old 07-27-2009, 10:25 PM
06F150STX's Avatar
at the other post Pat did for Pam.
  #22770
Old 07-27-2009, 10:30 PM
hey Pam
You rang, Sweetie?
Quick Reply: Let's start over......
