You have a K&N dropin don't you? You haven't serviced it recently have you?
Yeah the truck was gone through when I got it. But the truck gets low in the rpms and the engine seems like it wants to stall when it does this. The truck is 5 years old with 43k on it now, so I'd say the TB needs to be cleaned as it idled low to begin with and it seems the same thing has happened to many many people and then it is exacerbated once the tuner is installed. I just don't want to get stranded.
Sure it's easy. Just a setting. Go into the custom settings and click thru till you come to the one that says Idle RPMs or something like that and click the up arrow till you get to add 200 rpms. You need to check the manual, see what it says. Been 3 years or so since I messed with that.
Ok thanks Blue. Let me ask you this then. Is it normal that my truck when it is very cold does not want to downshift after I first leave from work? It takes a bit and then it drops down after I back off when driving throught the parking lot at low speeds. It also takes some time in order to get into OD in the cold. Is that because the truck needs to warm up even more?
