Brake Lights
Tail lights
And Rear Reflectors
http://www.txdps.state.tx.us/vi/publ...l/chapter4.htm
Inspect for and reject if:
1. Required lamp or lamps are not present.
2. Lamp is not securely mounted to the vehicle.
3. Lamp does not emit a red or amber light which is actuated on application of the service (foot) brake.
4. Lamp is not visible from a minimum distance of 300 feet to the rear of the vehicle to which it is attached.
5. Lamp lens is painted, missing, discolored, or does not fit properly.
6. Wiring is shoddy or electrical connections are poor.
7. Lamp projects a glaring or a dazzling light.
8. Lamp is not mounted on rear of vehicle.
9. Lens is cracked or broken to the extent that a portion of the lens is missing and/or separated, permitting light from the bulb to emit through the crack or break.
# Inspect for and reject if:
2. Lamp is not securely mounted to vehicle.
3. Lamp does not completely emit a red light plainly visible 1,000 feet to the rear.
4. Lamp lens is painted, missing, discolored, or does not fit properly.
5. Wiring is shoddy or electrical connections are poor.
6. Lamp is not wired so as to be lighted when head lamps or auxiliary driving lamps are lighted.
7. Lamp is obstructed by any part of the body.
8. Lamp does not emit a red color. (See note, pg. 4-26)
9. Lamps are not mounted on the same level and as widely spaced laterally as practicable.
10. Lamps are not mounted on rear of vehicle.
11. Lens is cracked or broken to the extent that a portion of the lens is missing and/or separated, permitting light from the bulb to emit through the crack or break.
1. Reflector is not present.
2. Reflector is not of red color.
3. Reflector is not properly and/or securely mounted to the vehicle.
4. Reflector is cracked to the extent that the reflecting ability is impaired.
5. Reflector is discolored, deteriorated, or painted.
6. Visibility distance is not as required.
7. Requirements shown on lighting diagram are not met.
Well, the clothes she buys require a lot bigger box than they used to!
