If I had to settle for something that small, I'd drive them both to see which one I liked.
When I'm at the dealer, all they can talk about is the EcoBoost. The service manager I know thinks it is the only way to go. I hate the sound of a V6 and I am hesitant to go for anything new. I can't help believe that working that engine and turbo that hard will require more maintenance, but maybe that is all wrong.
Actually, the more Torque/HP your engine has, the less it works. The less it works,the lower the temps. Turbo's throw the heat thru the exhaust. So, personally, if there was a concern, it would be with the turbo set up itself. I mean Ford knows how to build an engine.
If you don't like the sound, then go with the 5.0. I'm not sure which one I would choose either. I would have to drive them both.
Good point Jbrew... you guys remember that camdenlake user who did the V-10 swap in his 2000-2003 F-150? His mpg average shot up with that big engine cause it was working way less.
I'm with you Jim, I can't help but think there will be some issues with the turbo, but then again, the technology has been around for quite some time. Here is my reasoning on the motors tho. If I'm buying a V6 in a truck, it would be a 2wd reg cab 3.33 rear end 3.7 2011. If I needed a lot of power, I'd just get a superduty. I think people are acting like the truck is a 3/4 ton diesel. It's not and never will be. My Dad's (now my brother's) 1990 F-250 5.8 has way less power than the new motors. It got the job done for years pulling our trailer on hills and such. Where you don't do much towing other than your tandem axle trailer from what I see, the 5.0 is the most economical choice. That's just me. Anyone that tows a sizeable trailer should be looking at a 250/2500+ with a big v8 or diesel for the extra power and handling
This is not really relevant, but back in the late 80s, I had a friend with an 87 Grand National. I had a 1954 Ford F100 with a 351 Clev 4V, 4.88 gears and nitrous. We would race almost every weekend for 1/4 mile. From the standstill, that Buick would take me off the line so far that you would think there was no way I could ever catch him in a 1/4, but about 2/3 down the strip, I would blow his stuff in the weeds and pull away. He never beat me. That thing had tremendous low end torque but ran out of engine about 2/3 down the track. I'm wondering if the EcoBoost is similar or if it is completely different.
They all run hard when racing lol. Under normal acceleration is more less your usable Torque /HP. That's where it's at, for the DD. Less effort to weight ratio.
Yea TruckGuy, - I'm looking for a good deal on a V10 for the 98. IF the 5four ever gets weak. That's going take more time. I can't pull it without reason damnit. 274,000 miles and it's still putting out more power than spec. Doesn't burn, use or leak a drop of oil. That's a Ford reman engine tho, -my first blew @ about 30,000 miles. Still has the Original heavy duty trans tho.
Yep, a Chevy Nova. That Cleveland loved eating Chevys, big blocks and small blocks.
The mods were:
Crane Fireball cam, pretty radical
Holley alum intake, medium rise
Holley 850 double pumper
Holley high volume fuel pump
4.88 gears
Built C-4 automatic
Ford dual point distributor
Mallory ignition stuff
then later, 175 horse nitrous set up.
Best time was 12.96 at 98 mph at Little River Raceway, Little River, TX. That was on the bottle. Off the bottle, the best was a 13.88
Obviously, traction was the key.
4.88 gears
Built C-4 automatic
