Old 08-25-2011, 01:17 PM
Originally Posted by 88racing
Some explanations I found.....
A: You should not top off the tank. Topping off the tank increases the likelihood of spills and can cause excess fuel to evaporate in the air. When this happens you are polluting the environment and wasting money spent on fuel that you are not using. Fuel vapors are toxic and bad for your health. Overfilling can also cause your car’s fuel vapor system not to work properly. Besides, your tank needs additional space for fuel to expand. To avoid any potentially hazardous situations, stop fueling when the pump clicks the first time.
The closed positive ventilation and vapor recovery system needs a certain amount of compressible air volume or free surface area to operate properly. Completely filling the tank may force fuel into the vapor recovery reservoir and might damage the fuel pump or make the car stall or run poorly. I think most gas caps do have a vent to let air into the tank to replace the fuel that is sucked out but, the hole is so small that it doesn't really play a big role while the car is running. Also, the fuel from the underground gas tanks at the gas station is colder than the air in summer and can expand and leak through the gas cap vent causing a strong fuel smell or even a small fuel spill.
I don't spill it so the first one is out. Second one, I don't know. I fill it to the baffle in there, where I can visually see the gas, not to the outside lip.
Old 08-25-2011, 01:30 PM
When you fill past the overflow inlet into the filler tube is what can cause damage to the evap system.....circled in pic
  #65898
Old 08-25-2011, 01:32 PM
dsq3973's Avatar
Just got a call from the tire shop, they said my right hand tie rod and ball joints were shot and the only way they felt comfortable giving me the truck back was fixing it. The truck was going to go in next week for ball joints and axle joints any ways so it just means I am only going to be with out my truck for one day and not two.
  #65899
Old 08-25-2011, 01:33 PM
Well, I have done that with every fillup for 6 years, so I have either destroyed it or I'm not going high enough to be a problem.
Old 08-25-2011, 01:36 PM
You're probably not filling it high enough......
  #65901
Old 08-25-2011, 01:38 PM
Hitting them darn snow banks cause it......
  #65902
Old 08-25-2011, 01:48 PM
dsq3973's Avatar
168k on the original fron end parts, I am not going to complain at all. You weren't going to find me tromping through that snow bank to get the loader. Plus people drive like idiots in the snow up here so I would rather replace the tie rod every year than hear the crash as some moron texting and driving on a snowy road plowed into the back end of my truck at 65mph. And if they survied the crash they probably not survive me........
  #65903
Old 08-25-2011, 02:05 PM
Micheal's Avatar
Good thing its not a chevy.
  #65904
Old 08-25-2011, 03:10 PM
Jim.....edit the post I quoted too.....
https://www.f150online.com/forums/4664092-post6.html
  #65905
Old 08-25-2011, 03:16 PM
Well, I thought I had edited it prior to editing your quote. Guess I failed to save it.
Old 08-25-2011, 03:28 PM
Just helping out.....
  #65907
Old 08-25-2011, 04:09 PM
dsq3973's Avatar
Well, I get a new hub on the front axle one of them was almost completely frozen in place and would not have engaged this fall if I would have needed the four wheel drive. Wonder what else they are going to find??
  #65908
Old 08-25-2011, 04:12 PM
Check out the thread in GD built ford fast? Mostly stock f250 running 182mph
  #65909
Old 08-25-2011, 04:17 PM
Dang Dave.....you're going to half to sell your rider to pay for the repairs.....
  #65910
Old 08-25-2011, 04:28 PM
dsq3973's Avatar
Nope......got it covered. Going to sell the boy to the gypsies instead.
Quick Reply: Let's start over......
