the only thing that happens to fluid over time is it starts to trap moisture, reducing its boiling point. Most manufacturors recommend brake fluid exchanges at a normal interval.
For instance LR recommends every 45k miles or 3 years
but does it absolutely need to be done, probably not, but also keep in mind you can screw up the system by introducing air bubbles if you dont know what you're doing
The TQs have their on quietner on the back of the pad. I don't use any cleaner other than rubbing alcohol if I see I need something other than just wiping off.
Thanks Jim, I hope everything goes smoothly on Monday
on
on
