R/C crawling
Thanks man!
Ax-10 I bought RTR. I changed...
-the motor out for a 55 turn motor
-geared down to a 11 tooth pinion
-memory foam inserts for the tires
- 200 Oz/in Servo
-alum rods on all the steering and axles
-front diff locked
-soft spring on front
-cut rear springs 1/2"
-added drop spring inside the shocks
-mounted battery on front axle to drop CG & increase climbing ability
Thats all I can think of right now, it sounds like alot but many of those parts are very cheap. Total I believe I have less than 500 in it as it sits.
- 200 Oz/in Servo
-front diff locked
