Condensation in tool box
Old 01-28-2009 | 08:57 PM
JNC995's Avatar
What do you guys do to keep condensation out of your truck tool boxes? Just picked up a tractor supply (Delta) box. Opened it up today, and the whole inside had a little layer on condesation on it. Kinda hesitant to put stuff in there if it is going to sit in there wet. Any sugg?
Old 01-28-2009 | 09:43 PM
shorse's Avatar
just wait untill the snow gets in and all the stuff inside is soaked in snow and frozen....
i added weather stripping to my TSC toolbox, now it's fine
Old 01-28-2009 | 09:46 PM
Djacobs28056's Avatar
I looked at my weather guard, and there is a rubber "Gasket" running the whole way around. Also, keep any bottles of water and what not, OUT of your tool box. TOO many things can puncture them.
Old 01-28-2009 | 09:54 PM
JNC995's Avatar
It came with some type of stripping, guess I'll check that out. It snowed/rained here the past 3 days, so I don't think that helped. But I'm looking to store stuff in there that I don't want water to sit on.
Shorse, Once you put the weather stripping on, it didnt leak anymore at all? What size, type of stripping. Where did you run it?
Old 01-28-2009 | 10:01 PM
shorse's Avatar
when summer rolls around and i am not freezing when i work on my truck, i will take the stock w/s out and put the stuff i had used there.
I used 1" wide by 1/4" thick weather stripping, found at lowes... for doors and what not..
i put it on where the two doors hit the box, cause it would not stick to the old w/s...
i adjusted my latches vertically ( real easy, just loosen a bolt and slide it) to make them tight and seal, but not to tight to not close....
worked like a charm
Quick Reply: Condensation in tool box
