ford probe gt people
Old 08-14-2009 | 06:22 PM
Camarothatcould's Avatar
what do we know about em? 2.5l DOHC, any good???
any good forums?
Old 08-14-2009 | 10:55 PM
Couldn't tell you, I have a fe2t.
www.probetalk.com www.mx6.com
Old 08-15-2009 | 03:06 AM
Paralyzer's Avatar
i had a 94 GT. loved that car. the 2.5 can scream i drove it hard and rarely had any problems.
Old 08-15-2009 | 09:11 AM
Klitch's Avatar
i got one for sale. screamin deal. $2k all mechanically sound. fresh motor trans and susp/steering.
run away from the auto, the manual is a blast to drive, parts can be hard to come by.
on PT forums, use the sreach button. they're **** about it most days.
you'll also want this guy on your list of websites http://www.gummygrip.com/
i can help w/ most things on the gt after i've been through mine a few times.
Old 08-15-2009 | 10:43 AM
its a 96, got 113k on it, 5 speed, body is rust free and MINT with blown motor... picking it up for $150..... want to fix it, learn manual, sell it/trade it for a quad... I Cant believe how mint the body is and interior
Old 08-15-2009 | 10:46 AM
96 is a good year since they stopped making them in 97, made them a mercury cougar after that for a bit. Check out those sites and do some research.
Old 08-15-2009 | 10:52 AM
thank you
Old 08-15-2009 | 07:28 PM
Klitch's Avatar
OBD 2 is much more friendly than the obd1 cars
have the engine rebuilt by someone you trust.
Old 08-16-2009 | 07:58 PM
I trust myself.....
Any known reasons of why these engines let go???
Old 08-16-2009 | 11:02 PM
Krohbar's Avatar
I almost bought a 96 GT back in 99. It was red, moon roof, manual, but it didn't have the spoiler, so I passed. I got a Ranger instead. Never went back for a car again... Man, I wonder what I'd be driving now...
Old 08-17-2009 | 12:03 AM
Klitch's Avatar
poor oiling system. rod bearing #6 prone to failure from lack of oil, the porting sucks or something to that effect. theres a write up on a 3mm shim under a spring for the oil pump that helps a slight bit.
aside from that high rpms will eat head gaskets. the jugs resonate, because its got pretty sizeable water jackets around the cyldinders. more pronounced with boosted engines.
more often then not, its a toss up between #6 failure or pure overheating.
when rebuilding beware the vacuum lines, theres diagrams online in case. theres a "bitch bolt" that bolts a bracket to the right head and the block... some engineers i tell ya... just drop that bracket and ty it off, conveniently lose the bolts for that one.
Old 08-17-2009 | 12:15 AM
I have the cradle along with engine and trans, struts, brakes, everything all together in the back of the Expy. I will get it out sometime this week... How should I go about this? do you think I should Tear down the oil pan first or just pull the heads off? Should I rebuild or look for another one?
or, should I look for something else to swap in there, what else will work?
Old 08-17-2009 | 12:34 AM
Klitch's Avatar
you could go J spec and get a klze import, hp gains stock for stock rumored 30hp max peak difference.
rebuilding you need to find out cause of failure. comp test for lifted heads (check timing too, possible for the timing belt hydraulic tensioner to give and slip timing), address if necessary, you *can* drop the pan and girdle, then visually inspect the lower from there.
the cost of a full rebuild w/ shop labor was 1400 for me. that was bored, aligned and balanced before long block assembly.
all comes down to $ and what you really want. u can typically pick up a klze for 800 or so, then tear it down and clean it. voiding the warranty but depending on ur source, wouldnt matter anyway. the problem with a used engine, even the klze, is you dont know how it was treated before and 90% seem to have been rodded to hell. after you drive the car youll understand why though
Old 08-17-2009 | 03:53 AM
any idea of a rebuild kit I can find online??? I can leave boring to a shop, but I can assemble lower end components myself
he said one day it just started running rough, barely made it home. He tested it and one cylinder had no compression, 2 others it was low
Old 08-17-2009 | 09:15 AM
Klitch's Avatar
same bank? maybe timing but probably lifted head. it was difficult to find a kit online, heres one i remember looking at though. http://www.rpmmachine.com/engine-rebuild-kits-ford.html
if its a lifted head, get it decked. check ur block too, dont skimp of fudge, these motors picky about these surfaces.
oh, high quality head gaskets too. now would be the time to do long tube headers if your even considering it
Quick Reply: ford probe gt people
