LCD TV Help
LCD TV Help
2-3 years ago I bought a Phillips 42" LCD HD tv. It's been great; BUT --- in the past few months a shadow (actually two) have begun to appear on the screen. The set, though expensive, is long out of warranty.
I captured a picture of the primary problem - yes I know it's upside down, but you can still see the issue. My question is, has anyone else seen this develop on their LCD set - regardless of make/model - and if so, what was the fix?
At present the problem is not so bad as to make the TV unusable - usually you can't even see it except when the overall background is of a light color and the action is slow. (There is a second, less noticeable shadow in the upper left corner).
Is the set dying? (Odds are it's cheaper to replace than repair.)
Hi.
Panel defect, most likely.
The artifacts are called 'Mura'.
==> http://www.avsforum.com/avs-vb/showthread.php?t=1063679
MGD
MGD
Not what I'd call normal, but it is a problem with LCDs. The monitor I have for my laptop has terrible horizontal banding, but there's not much I can do for it since it's a few years old.
You could contact Samsung and see if they'd be willing to work with you. Try to get some pictures to send them.
