Odometer Test Function Setting
Old 03-07-2002 | 09:51 AM
cslinger's Avatar
Post Odometer Test Function Setting
I posted this in the electrical section but wasn't sure if I should post here also. Anyway here goes.
I know how to put the Odometer into test mode and read things such as digital rpm, speed etc.
What I was wondering if anybody has a listing of what each function means. There must be 20 different readings, many of which are not self explanetory.
If you could let me know where to find this information I would be grateful.
Chris
Old 03-07-2002 | 12:48 PM
sread's Avatar
I wouold like to know too, since the seasrch function isn't working maybe someone can help.
I have "scrolled" through the different codes and have some questions:
When I see fuel and then a number like 186, does that mean ther is 18.6 gallons left?
Also; isther a setting or code for the water temperature?
I want to know if I can drive with this setting in place to monitor the radiator temp while towing.
Can this be done?
Old 03-07-2002 | 12:52 PM
cslinger's Avatar
On a hunch
On a hunch I figured that most domestic manufacturers use many of the same parts distributers, so I went out to a buddies late model Jeep and tried this little trick.
It worked, although it ran a slightly different test routine and didn't seem to be able to be controlled. I am going to try a late model GM product next.
There has got to be a Ford Tech on this board who is willing to let the cat out of the bag on this one. What do all the functions mean?
Thanks again
Chris
Old 03-07-2002 | 04:47 PM
cslinger's Avatar
I also posted in electrical
And this is what I got.
http://www.mustangworld.com/ourpics/News/99hec.htm
Enjoy.
Thanks again for the help
Chris
Old 03-07-2002 | 08:26 PM
LIGHTNINROD's Avatar
Can this be done?
I d/k what the 'fuel' reading means but it does not have anything to do with fuel quantity,
Yes you can read your ECT(eng. coolant temp.) as you drive. If I remember, it shows 'engc82(or some other Celcius reading). It will change--up and down as your eng. and coolant work togeather. I used this info after changing to a 160* 'stat just to be sure it wasn't running too cold.
Dan
Old 03-08-2002 | 07:03 AM
sread's Avatar
Thanks Cslinger and Lightingrod!
Its people like you both that make this an excellent site.
Quick Reply: Odometer Test Function Setting
