Factory 6CD Stereo
Factory 6CD Stereo
Hi
My truck came with a single cd stereo with no sub connection. I purchased a 6cd Factory stereo with sub connecton and made my own harness for sub.
Everything works great.
My question is how hot should the factory 6cd stereo get? At first I thought I wired the sub wrong even though it seems to work right, so I unpluged the sub from the back of the stereo, but it still gets hot. Hotter then the factory single cd without sub connection gets.
Is this normal?
Is this normal?
I believe the 6 disc units are "Premium" and kick out more wattage than the single discs. More wattage means more heat. Modern electronics get hotter than people expect. Two things to check. Make sure your speakers ohm resistance matches the head unit. If you're using stock speakers then you're fine. Second, make sure you're grounded properly. If you're using the factory harness then it is.
Chances are very good that what you feel is natural. Damn, now I sound like the dad on "American Pie"....
Hi
Is this normal?
Is this normal?
Part # were
3u2z-14s411-dla Head unit
3u2z-14s411-caaa sub
Wiring goes
hu pin 3 > Sub pin 9
hu pin 1 > sub pin 7 shielded
hu pin 2 > sub pin 8 shielded
hu pin 4 > sub pin 1 shielded
pins 5 & 6 on sub hot all the time
pins 2 & 3 on sub Ground
The Pin numbers for the sub our not on wiring harness connector they are on inside of connector on amp. Very hard to see.
Can you still get the head unit side of this harness my truck has the subwoofer Barnes so I was going to reuse it and get the 4 pin from you please let me know asap
I will try and help here a little, looms get a little tricky. But since I am an official sponsor of this site I hope to have members refer some business my way if I can prove to you guys its worth doing business with me.
3U2Z14S411DLA is the 14S411P
3U2Z14S411CAAA is the 14S411F
Ed
Ed
