JVC KW-AVX810 pics.
JVC KW-AVX810 pics.
I just installed this head unit in my 2005 F150. The main reason it took me so long to upgrade the HU is I did not want to get a single din unit. Having had my car broken into before and having stereo equipment stolen I wasn't going to get a double din touchscreen because nobody made a decent unit that had a detachable face. Then I found this one. I've had a JVC television for years and haven't had a single issue with it, so I decided to give this HU a shot.
Got it from Sonic Electronics on ebay for $375. SE is an authorized online JVC dealer, main reason I went with them.
SE sent me a Scosche fd1426b dash kit, which I had to modify a bit to make work. No problem.
![](http://www.beachaudio.com/images/products/fd1426b.jpg)
Also sent a Scosche fdk11b wiring harness which is for an audiophile truck, which I don't have, but it didn't matter.
I spliced the two harnesses together and it was a piece of cake. It did then take a bit of fine tuning to make the dash kit fit right in the dash opening. Not really a fan of the plastic mounting points on this dash kit, but what the heck. I had to shim under the top two legs of the dash kit to make the kit sit right in the opening. Good thing the dash trim on these trucks is so easy to remove because I must have taken it off and put it back on about a dozen times or so before I was satisfied with the dash kit.
OK, here's the pics. Don't mind the dust and fingerprints. :o
![](http://i215.photobucket.com/albums/cc235/supergstealth/DSC00396.jpg)
It does protrude from the dash a bit (detachable face) but I am very satisfied with it. Looks like it belongs there. The dash kit is slotted and I could move the HU back some if I choose to, but that will come later on since I will definitely be back in the dash at some point in the near future.
![](http://i215.photobucket.com/albums/cc235/supergstealth/DSC00404.jpg)
![](http://i215.photobucket.com/albums/cc235/supergstealth/DSC00397.jpg)
![](http://i215.photobucket.com/albums/cc235/supergstealth/DSC00398.jpg)
![](http://i215.photobucket.com/albums/cc235/supergstealth/DSC00399.jpg)
![](http://i215.photobucket.com/albums/cc235/supergstealth/DSC00400.jpg)
![](http://i215.photobucket.com/albums/cc235/supergstealth/DSC00401.jpg)
![](http://i215.photobucket.com/albums/cc235/supergstealth/DSC00405.jpg)
Now taking into consideration this is the first piece in my audio upgrade, the unit sounds phenomenal with only the stock speakers. I will be upgrading the front door speakers with PG 6.5" amplified components and switching the rears with polk 5x7's, and I'll also be installing amplified 2 Id 10" speakers in a dual underseat enclosure.
Also if you're interested in bypassing the parking brake switch just ground the light green parking brake wire in with the ground wire.
All in all for the 15 minutes I've actually had this unit on and played with it I am exceptionally pleased with this purchase.
stealth,
I HAD a double din in my 04 f150 and it was "heavy" for a head unit and after a couple months I noticed it started to sag a little bit because the bracket wasn't strong enough for it. I never really fixed it, but 6 weeks ago (after having it in my truck for a couple years) I went over a speed bump and the weight of it finally snapped the bracket. I'm about to do a complete overhaul of my system and I will be finding a much stronger bracket for my new head unit, or I'll end up making my own, cause it was pretty annoying to watch my head unit fall into the dash! LMAO
- NCSU
stealth,
Cool deal. Just wait till you upgrade to amplified speakers and some subs. I had the audiophile package and it doesn't come close to the JL set up I have now. Although my left front speaker has been cutting in and out some, I think there's a loose connection some where. I need to open everything back up and tighten everything down since it's been almost a year and a half or more since my original install.
- NCSU
- NCSU
![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
Nice!!
Nice unit Stealth. I've been a fan of JVCs for the last 12 years or so. I've put one in every vehicle we have around the house (mine, the wife's, the kid's) over that time period and have never had a problem with a one of them. They've all worked flawlessly and sounded great. Here's a pic of my NX-7000,
same as yours just a few more bells and whistles. If you go to my photo album you'll see some pics of what I did to the bracket (metra kit) to get mine to sit flush and I know what you mean about the taking out and putting back in a dozen times, I had to do the same thing. As for the unit falling into the dash from the weight of it, I installed mine a little over a year and 1/2 ago and haven't had any issues with it sagging or coming loose and I've had it out a couple of times since the initial install to put in a rear view cam and other stuff. It has worked and sounded great even though I'm powering it w/a 12 year old Kenwood 280 amp,(I know, weak, not the Kenwood, the amperage). Pm me if you want to know about getting the unit to sit flush, cause there's a little more modification to do to the surround of the dash kit so it will open and detach that I should explain in detail.
edit: just read your other post about the dash kit Stealth, the Scosche kit looks just like the Metra kit so I don't know if it's any better than yours. I used a little locktite glue to hold mine together and haven't had any issues.
![](https://www.f150online.com/forums/members/mitch150-albums-jvc-kw-nx7000-picture6687-tricky-do-but-unit-sits-flush.jpg)
Thanks Mitch! The pics from your album are exactly what I needed to see. I can see the difference between the scosche and metra kits now. Going to get one this weekend and re-do the mount. ![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
Just ordered the Metra 95-5812 dash kit for $10 shipped off eBay. I'm going to make it sit flush like yours.
Thanks again!
Thanks again!
Thanks again!
Thanks again!
