Watch DVDs while in drive
watching movies while driving is illegal had to do it
you can wire a switch up to the wire out of your Headunit that is suppose to go to your parking brake
you take a pass thru switch, you run the Parking brake wire from the headunit to one side of the switch and a a wire out the other side of the switch and ground to a metal surface so then you can flip the switch and it thinks you have the parking break engaged so you can watch movies at anytime moving or not
hope this helps
hope this helps
Thanks, Stealth! I'll try the grounding first, then the switch if needed. Feel better, dude. - Og
I have the Kennwood also, and with nav. All you need to do is cut the wire at the splice that goes to the parking brake and ground it somewhere else. Problem solved. If I remember it was a green wire. I did it a couple days after I had it installed by pro's. I don't watch while driving, but its nice that you don't have to use the brake. I have a picture of mine.
If your not going to watch it while driving then whats the point?
