Noel and others who need SPAL fan info.....
Old 01-09-2003, 09:02 AM
Speedin Bob's Avatar
Location: On the side of the Road attempting to explain 135 miles per hour
nice writeup Sir Soap.
Old 01-09-2003, 09:32 AM
GLightning's Avatar
Thanks for the Info Soap! Excellent Post.
Glenn
Old 01-09-2003, 10:54 AM
dionisio's Avatar
Registered User
IC Fans
Great set up. Is there any way to have the fans work off a thermostat instead of a manual switch. Does anybody know if the intercooler is operated by a thermostat or is it on all the time? Or would it be simpler to have the fans on all the time since the power draw is quite low?
Dion
Old 01-09-2003, 10:57 AM
soap's Avatar
No the IC pump is not on all the time. You could tap the power line off the fans into the power line going into the pump (white wire). This will turn the fans on/off when the pump goes on/off. I wanted to be able to turn mine on/off whenever I want so I could run them in the pits without the truck running when it was cooling off.
--Joe
Old 01-09-2003, 11:13 AM
SLVRLTNG's Avatar
Great info Joe...I'll bookmarf for future reference....JR
Old 01-09-2003, 11:40 AM
smokingozzy's Avatar
Thumbs up
Joe, Thanks for the great info! It will come in handy. Jim
Old 01-09-2003, 11:41 AM
dionisio's Avatar
Registered User
THanks Joe,
Currently, I only have a 2lb pulley. There is no doubt that with a 6 pounder allot of heat is produced. Would it make any difference with a 2 pounder?
Dion
Old 01-09-2003, 12:23 PM
LIGHTNINROD's Avatar
Joe/Soap:
Dan
Old 01-09-2003, 12:38 PM
Don's Bolt's Avatar
Thanks Joe
Old 01-09-2003, 06:13 PM
HANKFAN's Avatar
Is there any other benefit from using these fans other than cooling down at the track? If you were to leave them running while driving would you be able to see a decrease in operating temps?
Old 01-09-2003, 06:26 PM
VINNIE's Avatar
Mine are tied into the pump and on a switch.
In my opinion anything that makes the truck run a little cooler and more efficient can not be a bad thing.
VINNIE
Old 03-13-2003, 07:52 PM
FastMatt's Avatar
thanks!!
Old 06-19-2003, 01:42 PM
l-menace's Avatar
yeah
yeah that is EXACTLY waht I was talking about.
thankx
SOAP!
Old 06-19-2003, 08:44 PM
JewishLightning's Avatar
What about running 3 of the 6.5" fans on the JDM Heat exchanger? I'm upping my lower 6 with an upper 2 so this is really important for me to have with the stop adn go traffic and the heat down here in Florida.
Old 06-19-2003, 09:30 PM
easterisland's Avatar
Jeffs Lightning says the 8" permacool fan flows 800 cfm.
Quick Reply: Noel and others who need SPAL fan info.....
