Help
Help
I need a picture of the front under carriage that has
the intercooler flap attached to the front ground effects.
I think FORD put mine on backwards. The rubber flap
is on the bottom of the ground effects instead of on
top and behind.
This resulted in the little plastic pins that stuck out
(Maybe the wrong pins?) getting broken off on the sidewalk
(Whups that was close!) and dropping the rubber sheet down.
Anyone have a pic like that??
TIA
Cliff
top and behind.
TIA
Cliff
Dan unfortunately I have to work tomorrow from 12noon to 6pm... I do have Sunday off though.
SVT_KY: No I'm ashamed to say SpankDog is correct and that is bright rust, not sure why that part wasn't painted from Ford but I do have plans on painting it black like it should be when the weather warms up some. As a matter of fact you can see some moisture in that picture on the box.. that is the first I have noticed that so I guess I need to take a closer look tomorrow when the sun is out.
Johnie
Johnie
Oh yeah Dan I also wanted to ask how many other Silver L's are there in Macon? I seen one that was a '01-'02 with NO front license plate holder and It had some sort of football sticker on the back window. I seen it Dec 29th at Logan's when we were leaving... I almost went back in to ask who's it was. Then I thought of a nice parking lot burnout to "draw" them out but common sense kicked in (and the wife) and I drove away calmly hehehe
Any idea who it was?
