Basic Maintenance
well, the oil is changed every 2500 miles, fuel filter every other oil change. i'll probably never change the diff. fluid, but i probably will change the trans fluid every 10K or so when i get the shift kit, with the new pan, cause it's got that drain plug for it.
and i'll probably do plugs every 25K or so, i don't plan on going big on mods though either, just a 3 or 4lb pully, a filter, a chip, a shift kit, and other than that it's all gonna be appearence.
Originally posted by cpeapea
i change my oil every 2k, im nearing 13k on my truck and am debating changing to a full synth...which oil do you recommend ?
5w-30 0w-30?
5w-30 0w-30?
Dan
8200 miles and..........................
On my 3rd fuel filter.
Change oil (Mobil1 synthetic 5W-30) every 3 trips to the track. I don't go by the mileage rule.
3rd set of plugs. Stock, NGK TR-6's (sucked BTW) and now the blessed Denso IT22s (No miss, no drips, no errors)
Sunoco Ultra 94 at all times. Sunoco 104 GT unleaded in colder weather conditions at the track.
One complete transmission flush by JJSSVT.
Expensive yes, but not my daily driver. Also, I consider it cheap insurance in that I'm treating the L right and respecting the abuse I inflict on the engine and driveline. Overkill to many I'm sure. My philosophy is better to pay now than later.
BTJ
BTJ
Re: 8200 miles and..........................
BTJ
BTJ
VINNIE
