Basic Maintenance
Old 01-15-2003 | 12:52 AM
VINNIE's Avatar
Basic Maintenance
O.K. after reading the fuel filter thread I have to say that with all the mods that nobody has a problem buying(myself included)
You must do at the VERY LEAST basic Maintenance. If you race ,even not that often then you need to do more.
In 20,000 miles I have a lot of 1/4 mile passes but I have changed my fuel filter 5 times, oil 11 times , tranny fluid 4 times and rear end fluid twice.
I check my plugs reguarly and I am always looking for something that I can improve.
Does this mean my motor will not blow up, NO or that I will not throw a plug,again NO but I am doing what I think is right to keep the L running good.
So please before you buy the next mod think about basic maintenace.
I know this does not apply to everybody and a lot of people do way more then me but just something to think about.
VINNIE
Old 01-15-2003 | 01:29 AM
SCOTTSBEATER's Avatar
I can't believe you forgot to mention blinker fluid.
Old 01-15-2003 | 01:34 AM
VINNIE's Avatar
LMAO
Old 01-15-2003 | 01:37 AM
J15BIG's Avatar
how often should tranny and rear end fluid be changed? where can you get rear end fluid and what is it called?
Old 01-15-2003 | 01:41 AM
rear end fluid.
JK it's called differential fluid. Ours use synthetic from the factory. You can buy it at any parts store or from the dealer. Read Superfords write up on changing out the girdle to get a good idea on how to go about changing it. Great pictures with him wearing rubber gloves....
Old 01-15-2003 | 02:01 AM
J15BIG's Avatar
rear end, differential....same thing
ill check out superfords post
Old 01-15-2003 | 06:38 AM
dealerjim's Avatar
Re: Basic Maintenance
Vinnie,
Do you change the tranny filter every time you change the fluid or do you just drain and fill it?
Old 01-15-2003 | 06:51 AM
loosebolt's Avatar
Right on Vinnie
Just remember, if you notice a change after a new filter or fluids, then it is probably too late.
Old 01-15-2003 | 07:32 AM
Krix330cic(NJ)'s Avatar
Yep. Today im going for the Rhino ramps, Syn. oil, filter, and fuel filter (again!).
Old 01-15-2003 | 07:35 AM
The Swede's Avatar
TRUCK OF THE YEAR - 2010
Good point Vinnie ! ! !
I change oil and filter every 3000 miles in the engine
Trans fluid with filter and diff fluid every 7000 miles
I go to the track maybe 5 - 6 times a year.
Old 01-15-2003 | 08:15 AM
yysenhimer's Avatar
Can't blame him for wearing gloves. That fluid stinks up the whole garage and it is hard to get the smell off your hands. I almost chummed the first time I took a diff cover off to do a set of gears.
Old 01-15-2003 | 09:34 AM
ShadowBolt's Avatar
Vinnie, I know basic maintenance is important and overdoing it won't hurt anything but.....
I change my oil (10-30 Valv.) every 5000-6000 miles.
In 64,000 have changed the trans. fluid once (when installing the F/T shift kit) at 30,000 miles.
Fuel filter once at 36,000 miles and it was still very easy to blow through.
Changed plugs once in 64,000 when I went from a 2# to a 4# pulley.
Maybe I have just been lucky. I don't go to the track very often (5 or 6 times in 3 1/2 years.
Jerry
Old 01-15-2003 | 09:43 AM
RTKILLA's Avatar
well my oil gets changed atleast every 3 months, I barely put 3000 miles on a year now with how much I drive her.
The fuel filter gets changed once a year now, before every 10,000 miles.
My coolant has been changed out once so far
My tranny is the fourth one in 42,000 miles so I got that pretty much covered with new clutchs and everything, HAHAHAHAHHA. I still try to changed it every year in the winter now.
spark plugs get pulled on my truck probably ever 1000 miles or so, just precaution I guess.
The blower fluid got replaced with the new supercharger about 5,000 miles ago.
The one thing I haven't changed yet is that differential fluid EVER! I know its probably bad that I haven't and I should get that done this winter. Probably going to get the new cover and do it then.
And I do try and get to that blinker fluid on a regular basis!
Old 01-15-2003 | 09:57 AM
HANKFAN's Avatar
According to Ford the differential fluid is synthetic and is considered a lifetime fill. So you shouldn't have to change it. And it should be a lifetime fill because the Ford synthetic gear oil from my dealer is $18.00 a quart!!!
Old 01-15-2003 | 10:44 AM
Fast Gator's Avatar
I have 13500 on truck after Fla trip
Changed the oil and filter at
100 miles
1000 miles
3000miles
5000miles
7000miles
9000miles went Amsoil synthentic
Changed the tranny at 5000
went with Amsoil synthetic
will trade for an 05 before change
Rear end
synthetic from factory
nuff said
Fuel filter at 5000
Due for fuel filter
Changed plugs at 5000
Blinker fluid
Gas is replaced every 300 miles
Quick Reply: Basic Maintenance
