O2 Sensors on Ls
O2 Sensors on Ls
I was told that our trucks (I have supercharged '02 HD, but I assume they are same as Ls) have two O2 sensors. I know one is on driver side of exhaust close to engine, but where is other one?
Also, how computer uses values from them? Are they averaged? Or they are read and processed independently? If one of them is malfunctioning what would happen? Would computer know that or it would get incorrect values and then make incorrect decisions based on incorrect values?
Thanks in advance!
ZoranC
Thanks in advance!
ZoranC
Originally posted by SpankDog Actually there are 4. 2 on each side, and then on each side one is in front of the cat and one is after the cat.
Also, when we hook up aftermarket A/F gauge, like Autometer, we usually tap into wire that goes from O2 sensor to computer. How many wires go from O2 sensors to computer? One, two, or four?
Also, do you happen to know can I find out what computer is seeing through OBD II / diagnostic port in real time?
Thanks again!
ZoranC
look closely at this picture and you'll find all four of them.
the two at the front nearest the exhaust manifolds are the HEGO's that monitor oxygen. They vary voltage to the PCM from 0.0v (lean air fuel) to 1.0volt (rich air fuel). HEGO stands for "Heated Exhaust Gas Oxygen", I think our hegos use 4 wires, two for the heater and two for the O2 sensor, but some hego's only have 3 wires.
The two at the rear near the tailshaft of the transmission are actually called Catalyst Monitors, all they do is monitor the air there and make sure that the catalytic converters are working properly.
later,
chris
later,
chris
What most of us do on Cobras when we want to run off road pipes is simple take out the two CM's and replace the wiring hardness with a MIL Eliminator which basically contains a diode and resistor wired up to fool the computer into the corrected voltage without throwing a MIL/SES light on your dash. This can easily be adapted on a Lightning as well if you choose to run offroad pipes.
Originally posted by superfords the two at the front nearest the exhaust manifolds are the HEGO's that monitor oxygen. They vary voltage to the PCM from 0.0v (lean air fuel) to 1.0volt (rich air fuel).
What I am also interested in is can one sensor send a signal "too lean, make it richer" while other one is at the same time sending signal "too rich, make it leaner" or any of other possible contradicting "statements" while both are operating properly? Or that can happen only when at least one of the sensors is malfunctioning? Also, what would computer do in such scenario? This is brainstroming on an idea that both sensors should be sending approximately same voltage at approximately same point in time and that if there is a significant lag or difference between two than something is wrong. I am trying to find out does this logic work or not.
Originally posted by superfords I think our hegos use 4 wires, two for the heater and two for the O2 sensor, but some hego's only have 3 wires.
Originally posted by superfords The two at the rear near the tailshaft of the transmission are actually called Catalyst Monitors, all they do is monitor the air there and make sure that the catalytic converters are working properly.
Thanks again!
ZoranC
hego is an acronym for your 1st pair of oxygen sensors. (forgot what it stands for) our L hegos use 4 wires, 2 to sense with and the other 2 are the heater wires, there are also o2 sensors with single wires, and 2 wires. i dont think o2 sensors have anything to do with testing for blockage, the most acurate way to do that is to weld in some sort of pressure tester. most likely any blockage would be the cats, if those arent it then it would be the muffler. most of the time a pipe just cant be blocked unless its been kinked. someone correct me if im wrong
Originally posted by cpeapea our L hegos use 4 wires, 2 to sense with and the other 2 are the heater wires
Originally posted by cpeapea i dont think o2 sensors have anything to do with testing for blockage
Thanks!
ZoranC
ZoranC, you have alot of questions and I don't have alot of time. As I said before, HEGO stands for Heated Exhaust Gas Oxygen. The sensor itself is heated, thus two wires power and ground for the heater circuit portion of the part, the other two wires are used to send the signal to the pcm. O2 sensors measure oxygen content, nothing else. Yes, it's possible that you could be rich on one bank and lean on the other and the O2s could be sending two different messages. so you are correct in you question about needing two guages. It really doesn't matter though, because the guages you are talking about aren't accurate anyway, you'd need a wideband o2 sensor on each side of the motor. an EGT in each header tube would be more accurate, but more complicated. The guage that I think you are talking about is mostly just for looks. Neither the upstream hegos nor the catalyst monitors will tell you if your cats are clogged. The cat monitor sensors also measure air, again, thats all O2 sensors can do, they then calculate lean or rich based on how much air they see. the upstream sensors switch from rich to lean to rich to lean, etc, if they do this the engine is running correctly, the cats change the Oxygen levels in the exhaust and the cat monitors should just read a steady voltage, IF they are switching like the upstream sensors, they you know that the Catalytic converters didn't do there job or aren't there. The only way I know to check for exhaust blockage aside from removing the exhaust is to use a vacuum guage to check manifold vacuum (intake), at idle you should have ( depending on type of engine) approximately 15-21inches of vacuum, if the vacuum signal is low this is an indication of a blockage, if you rev the engine or raise the RPMs this would increase the exhaust flow to the blockage and accentuate the readings if there is a blockage, but won't always show it if it is partial. BTW, why do you think your exhaust is blocked? it probably isn't.
good luck.
later,
chris
good luck.
later,
chris
Chris,
I completely understand. I am sorry about this avalanche of questions. Main reason for it is need to learn a lot fast without making mistakes. I've been having issues with my truck for a while and I have progressed some but not much. I go somewhere, they make one step just for me to find out what was done was incomplete so I have to go back in line, which costs me more time and more money, and sometimes thing have to be undone, and some parts are unneccessary or wrong, etc, and I don't have neither money nor time nor knowledge nor resources to do it myself, all while my truck is still having issues. So I have to stop that insanity and I have found out best way to do it is by asking lots of question around here. Just in last few days my knowledge has grown in leaps and bounds thanks to you and others that are helping me out so your patience and willingness to help and explain is already extremely appreciated.
Thanks to your explanations there are very few questions left and I promise they are short so if you could hang with me just a lil more I will be thankfull...
Is being rich in one bank and lean in other normal behavior or it could happen only when there is an issue with fuel or air delivery or when sensor is malfunctioning? Is there a way at all to say is sensor malfunctioning?
How one can know what is going on with air/fuel ratios (is one reach, lean, or just right) based on temperature of exhaust fumes from cylinder(s)? And should one monitor just two temperature values (one per each bank) or 8 of them (one per cylinder)?
What part about is complicated -- is it installation (tapping into wire vs modding the header tube) that you had in mind when you said that?
If you mean that I mean regular A/F gauge, then yes, we are talking same gauge. I am still undecided about these gauges. From all I read they are showing values only during regular drive and when I go into WOT computer is not reading out from them but is using embedded tables. My truck doesn't have issues during regular drive, it has issues only when I step on it hard. Therefore, I am suspecting those gauges wouldn't be of much help in my scenario (like already said). If that's the case I am tempted to ditch them and save that money for later installation of wideband O2 and EGT. In the meantime I could maybe, if I really want to see values from O2 sensors, get OBD II software, hook it up to laptop, log the data in real time and analyze it to my heart's content later, plus OBD II software would give me much more besides those 4 values. Any input/opinion on this?
Where on manifold intake you would hookup that gauge?
Because some people in forums told me I should check it out because it could cause symptoms I am experiencing. I know it is not completely blocked because I can see exhaust flowing from both tips and because none of the piping underneath is red hot after drive. I just want to check it out and get it off my back as "checked that, next".
Thank you again! As always, I am looking forward to your reply.
ZoranC
Originally posted by superfords you have alot of questions and I don't have alot of time
Originally posted by superfords it's possible that you could be rich on one bank and lean on the other and the O2s could be sending two different messages
Originally posted by superfords an EGT in each header tube would be more accurate, but more complicated
Originally posted by superfords The guage that I think you are talking about is mostly just for looks.
Originally posted by superfords The only way I know to check for exhaust blockage aside from removing the exhaust is to use a vacuum guage to check manifold vacuum (intake)
Originally posted by superfords BTW, why do you think your exhaust is blocked? it probably isn't.
ZoranC
Cooler EGT readings mean a richer mixture.
it would be adviseable to monitor each individual exhaust port. otherwise you'd just be averaging and this could mask a problem that you might be having on one cylinder.
hope this helps.
later,
chris
Originally posted by superfords No, that would not be normal behavior by any stretch, but it is not impossible.
Do you happen to know how many times a second computer readds out voltage from O2 sensor and adjusts A/F ratio based on that?
Also, do you happen to know how many times a second we can read out values from OBD II port?
Originally posted by superfords it would be adviseable to monitor each individual exhaust port, otherwise you'd just be averaging and this could mask a problem that you might be having on one cylinder
Originally posted by superfords the HEGOs are effectively just along for the ride during WOT
Also, wide open throttle is defined as throttle opening greater than 80% as indicated by the throttle position sensor. How do I know am I in WOT or not? How do I know what is value on throttle position sensor?
Hmmm, seems like a list of questions is getting shorter and shorter and easier and easier. Thank you for the opportunity to learn from you! I have much clearer picture now how things work.
Thanks again!
ZoranC
