Flow #s on ported heads
These are the flow #s on a test set of heads we just did. We wanted a few more shots at it before we let the numbers out, but someone got paraniod, so here you are.
5.4L SOHC PI Heads
Done on a Superflow 600
Test pressure 28"
Intake
Lift stock ported
.200 115.8 139.5
.300 147.3 184
.400 166 234
.500 173.7 236
.600 181 237
Exhaust
Lift stock ported
.200 99.5 114.5
.300 125 152
.400 142 188
.500 159 200
.600 163.7 204.8
We are pretty happy, but think they can be improved a little more.
See you at the races.
5.4L SOHC PI Heads
Test pressure 28"
Intake
Lift stock ported
.200 115.8 139.5
.300 147.3 184
.400 166 234
.500 173.7 236
.600 181 237
Exhaust
Lift stock ported
.200 99.5 114.5
.300 125 152
.400 142 188
.500 159 200
.600 163.7 204.8
HI!... Well TIM : Your port/polish job looks a lot better than these guys #'s. This was the flow chart from MUSCLE MUSTANGS & FAST FORDS. NON "P.I" heads ported VS. "P.I heads ported. Their ported #'s are still lower than your stock non ported #'s.
http://www.musclemustangfastfords.co...MMFF_MixMatch/
Looks like nice gains. When people compare flow numbers be sure you are comparing apples to apples. Make sure the measurements are taken at the same flow rate. In this case it is stated at 28". The numbers would be different on these same heads if the were done at 24". Just an FYI when you start shopping you need to know what the flow reading was done at.
Going .020 on a cobra motor with forged internals, keeping same compression and porting the stock dohc heads on my 98 yielded a rear hp value of 385. Combo of cubes and port work opened it up big time. 2V heads ported right will give you nice power and the ability to up boost. Concentration to the exhaust side is the important aspect.
