Lightningtuner!
Re: Lightningtuner!
Originally posted by sdf150guy
Seeing your name at the top of your list, I'm curious of what you have in your truck?? Thanks!
Well using the gear calculator, Let say Sal is running through the traps at 132mph with 3.55's and his 30" Hoosier Radials (29.5" actual height) his rpms will be 5,337.
Now let say JL runs the same as Sal, but with his 4.10's. (I believe JL has 4.10's) His rpms would be 6,164 rpms.
I wonder if JL really runs 4.10's?
*Note: Figures are corrected with a 3rd gear ( 1 to 1 ) ratio.
At then end of 2001, we had the fastest Gen 2 around, with our 11.20 @ 118 ET. However that ET came from running in 4th gear. At the time, the truck was accelerating so fast that we were hitting 6000 rpms by the 1000ft. So we had to upshift into OD to finish a pass, and that was hurting ETs. For the 02 season, I took the stock 3.73s out, put 3.55s in, and went to a 30" tire. So now we have an effective rear end ratio of about 3.30. With this combo, we now go through the traps right at 6k.
I'm not saying it'd be easy for FT or anyone else for that matter, it'd just be nice for the 1/4 mile.
