Intake Spacer
Originally posted by captainoblivious
wkuper11 - if you want an aluminum spacer and have the tools to work with aluminum, let me know, I have enough material to make 2 more spacers, and can sell you a slab to work with cheap.
Originally posted by wkuper11
...what tools do you need to work the material? ...
I'm sure a band saw with a metal blade with cut through ½" aluminum much easier then a scroll saw. But it worked.
You will also need to make extensions for the front of the plenum, and get material to make another gasket, unless you decide to permanently attach the spacer to either the blower or plenum.
